FM radio high frequency amplification and mixing circuit
Source: InternetPublisher:国民男神经 Keywords: Mixing circuit high frequency amplifier FM radio oscillator Updated: 2021/11/08
Shown is the high amplifier and mixing circuit of an FM radio . VT2 (2SC930) is the local oscillator of FM . The radio
frequency (RF) radio signal received by the antenna is sent to the base of the VT1 high-frequency amplifier , and then amplified by VT1 and output from the collector to the base of the mixer VT3.
At the same time, the oscillation signal of the local oscillator VT2 It is also sent to the base of mixer VT3. The two signals are mixed in VT3. After the
output selected by the intermediate frequency transformer Ti, the intermediate frequency signal (10.7 MHz) is sent to the base of the intermediate frequency amplifier circuit VT4. After VT4 is amplified, the collector
output is output through the intermediate frequency filter CF1. Then sent to the frequency identification circuit.
- Does lithium iron phosphate battery need a protection board? The correct way to charge lithium iron phosphate battery
- Which one is better, NPN or PNP transistor?
- An article explains the working principle of the Wheatstone bridge
- What types of power field effect tubes are there? Selection criteria for power field effect tubes
- What are the classifications of filters?
- What is a D flip-flop and how does it work?
- Diode-based clipping circuit
- Why use PWM? What are its advantages?
- Tutorial on building a NOT gate using BJT transistors
- LED Bicycle Lights
- Photosensitive automatic dimming desk lamp circuit and principle
- Patient call alarm circuit
- High reliability carrier oscillation circuit for emitter
- 7-tube superheterodyne radio circuit
- How to connect the load of capacitive three-point oscillatorb
- Typical relaxation oscillator and output voltage triangle wave
- Internal structure of CD4017
- Time base circuit AC dimmer circuit
- Comb oscillator (1)
