Typical DVD5.1 channel audio DA converter circuit
Source: InternetPublisher:兰博 Keywords: channel converter audio Updated: 2020/12/30
Shown is a typical DVD 5.1-channel audio D/A converter circuit, and the CS4360 chip is a D/A converter. As can be seen from the figure
, the digital audio signals (SDIN1-SDIN4), digital clock signals (SCLK1, SCLK2)
and digital separation clock (LRCK1, LRCK2) signals sent from the digital audio signal decoding circuit are sent to the D/A converter (CS4360 ), perform D/A conversion mode control, amplification
and other processing, and then output 5.1- channel (6-channel surround sound) analog audio signals to the post-stage circuit .
- The unidirectional conduction current of the diode, the diode and its common uses
- How do pull-up resistors work? How do I choose a pull-up resistor value?
- How do Zener diodes protect circuits?
- The Importance and Ideal Model of Impedance Matching
- RC filter explained in detail
- Simple Wired Spy Bug Circuit Built Based on IC741
- How to install the accelerometer
- What is the difference between JFET and MOSFET
- Experimental circuit based on 4040 binary adder counter
- Touch circuit design and analysis
- KBC-Ⅱ type programmable power circuit
- LTM8045 SEPIC regulator application circuit diagram collection
- DC/DC converter LTC3441
- Multi-channel surround sound audio signal processing circuit
- Audio DA converter circuit for multi-channel surround sound system
- 5.1 channel surround sound DA converter circuit
- Basic structure of DA converter
- Simple current-to-frequency converter circuit
- CA1524 push-pull converter circuit diagram
- Universal sine wave converter circuit diagram
