sawtooth oscillatorb
Source: InternetPublisher:拿铁三分糖 Keywords: Sawtooth oscillator potential BSP collector Updated: 2021/08/28
The more commonly used Pockels circuit is shown in Figure (c). First, - Vcc
is added to the base of VT2 through Kl, causing VI2 to conduct, and the capacitor C is charged through R. If k is selected, WR is large. Then the charging time is
longer than the discharging time.
c is quickly charged to the potential The voltage drop of R spit causes the base potential of VTI to become positive through Cl and is cut off.
When c is charging, the collector current gradually decreases, and the power supply voltage passes through the base of the supply and rri, causing VTI to conduct. In this way, the collector voltage of VT1
drops, because the base of VT2 is connected to the collector of VT1 , making \rr2 cut off. Since V12 is turned off, the charge on c is discharged through R until VT2 turns on again when
the emitter potential of VT2 is higher than the base potential . Therefore, periodic sawtooth
waves are generated at both ends of C,
- What is a Half Wave Rectifier? Working Principle of a Half Wave Rectifier
- What is the difference between single-phase and three-phase power? When is three-phase power required?
- Classification and characteristics of operational amplifiers, classification and characteristics of operational amplifiers
- What are the classifications of filters?
- How do you calculate the value of capacitors in series? Why use capacitors in series?
- Share an interesting LED decoration project
- Why use PWM? What are its advantages?
- Important things to know about PCB routing and how to design the right routing for your PCB
- Build a musical fountain using Arduino and sound sensor
- A practical automatic electronic welcome circuit
- Motor forward and reverse control wiring diagram (2)
- Agricultural small tractor lighting circuit
- Mixer built with analog multipliers
- Diode Balanced Mixer Circuit
- Frequency modulator composed of NE566
- Series crystal oscillator
- Double gate field effect transistor high frequency amplifier circuit
- Voltage controlled power supply second-order high-pass filter circuit
- Three primary color display circuit
- Digital stopwatch display circuit
