DC coupling circuit a that raises the base potential of VT2
Source: InternetPublisher:两手空空 Keywords: Potential coupling circuit DC coupling BSP Updated: 2020/03/27
.DC coupling circuit a that raises the base potential of VT2
In order to enable the two-stage DC coupling circuit to amplify normally, the base potential of the VT2 tube must be raised. The figure shows
a practical circuit for raising the base potential of the VT2 tube. Figure (a) shows that the emitter of VT2 is connected to a resistor RaZ. Although this method raises the base
potential so that both VT1 and vr2 can amplify normally, the second-stage voltage amplification factor is seriously reduced.
In order to raise the base potential without reducing the amplification factor of VT2 too much, Re2 is replaced with a voltage regulator tube D; as
shown in Figure 1-41 (b). The function of the resistor R in the figure is a current-limiting resistor to ensure that the voltage regulator tube works in the voltage stabilization zone.
- What is the function of a voltage regulator in a circuit? How to connect a voltage regulator?
- What does a rectifier do? What is the process of rectification?
- What is an ac to dc transformer in circuit design
- The Importance and Ideal Model of Impedance Matching
- Working principle and truth table of JK flip-flop
- Beautiful crown wreath made with LED
- How does RCCB work?
- Ceramic filter structure/working principle/characteristics/application
- Structural diagram and function of sliding resistor
- Using an Op Amp to Drive a Simple and Practical Power Amplifier
- Set timing circuit when power is on
- Ultrasonic blind pathfinder circuit
- soil content measurement circuit
- Peanut and melon seeds roasting machine circuit
- Poultry warming temperature control circuit
- Junction field effect transistor mixer circuit
- Double detuned loop frequency discriminator circuit
- Diode square rate detection circuit
- Schiller oscillator circuit
- Double gate field effect transistor high frequency amplifier circuit
