Two common-emitter transistor amplifiers connected to form a directly coupled two-stage amplifier
Source: InternetPublisher:拳制龙 Keywords: transistor amplifier coupled common emitter BSP Updated: 2020/09/10
Shown is a direct- coupled two-stage amplifier consisting of two common-emitter (e) transistor amplifiers connected . There is no coupling capacitor in the circuit
, and the DC voltage output by the front-stage common-emitter (e) transistor amplifier is directly used as the input voltage of the subsequent-stage common-emitter (e) transistor amplifier
Compared with capacitor-coupled multi-stage amplifiers, direct-coupled multi-stage amplifiers have better low-frequency response. However, when
a small change in the power supply occurs, it will be amplified by the circuit, causing obvious deviation of the circuit. The operating points of the two-pole amplifiers influence each other.
- The unidirectional conduction current of the diode, the diode and its common uses
- In-depth analysis of energy losses in oscillation frequencies
- Analysis of the basic principle of measuring resistance by bridge method
- How does sand become chips?
- Capacitance detection circuit configuration, how to deal with low frequency and high frequency noise?
- Datasheet/Pinout/Technical Specifications of LMC555
- Working principle and truth table of JK flip-flop
- Analysis of three simple electronic dice circuits
- How to build a triangle wave generator using an op amp and discrete components
- Introduction of TDA4863J/4863AJ TV field scanning IC
- Set timing circuit when power is on
- Egg warming circuit
- Crop anti-frost circuit
- Rural fish farming control circuit
- Straw returning to field crusher circuit
- DC ammeter
- Common emitter-common base wideband amplifier circuit composed of F733 integrated amplifier
- Voltage-controlled voltage source second-order active low-pass filter circuit
- Wireless microphone circuit
- Three primary color display circuit
