Common base transistor amplifier unit circuit b
Source: InternetPublisher:兰博 Keywords: transistor amplifier unit circuit resistor BSP Updated: 2020/07/11
The basic structure of the common-base amplifier circuit is shown in the figure. The key components are mainly bias resistors , coupling capacitors and amplifier
transistors. The four resistors in the circuit are all set up to establish a static operating point. Rc also serves as a load resistor for the collector (c)
; the resistor RL is a load resistor ; the two capacitors cl and C2 are The coupling capacitor serves to communicate AC and isolate DC; the decoupling
capacitor Cb is to directly ground the AC of the base (b) and serves as a decoupling capacitor, that is, to eliminate AC negative feedback.
The input signal is loaded between the emitter (e) and the base (b) of the transistor, and the output signal is taken
between the collector (c) and the base (b) of the transistor. It can be seen that the base (b ) is the common terminal of the input signal and the output signal, therefore, the circuit is called a common-base transistor
amplifier.
- The unidirectional conduction current of the diode, the diode and its common uses
- How do pull-up resistors work? How do I choose a pull-up resistor value?
- What does a rectifier do? What is the process of rectification?
- How does a series arrangement of Zener diodes affect the electrical behavior?
- What is the relationship between capacitance and impedance in an AC circuit? How do you calculate the impedance of a capacitor?
- What is an ac to dc transformer in circuit design
- Ideal characteristics of operational amplifiers/pin configurations/gain types/primary applications
- What is the difference between CPLD and FPGA?
- Ceramic filter structure/working principle/characteristics/application
- Make a flameless electronic candle using simple electronics and LEDs
- Motor overcurrent protection circuit
- electromagnetic field sensor
- Amplitude modulation circuit composed of MC1496
- Parallel crystal oscillator
- OTL low frequency power amplifier circuit
- common emitter amplifier circuit
- Second-order active band-stop filter circuit
- superheterodyne radio circuit
- Guest arrival signal recognition circuit
- Sawtooth wave generator circuit (1)
