transistor current amplifier
Source: InternetPublisher:李商隐身 Keywords: Transistor current amplifier BSP common collector Updated: 2020/06/10
(2) Basic functions of common collector
amplifier circuit
Common collector amplifier circuit outputs signals from the emitter
. The signal waveform and phase are basically the same as the input signal.
Therefore, it is also called emitter outputter or emitter follower, or emitter for short. Follower
, often used as a buffer. Figure 1-13 shows
the basic common collector amplifier circuit. Common collector transistor amplifiers are often used
as current amplifiers . They are characterized by high input impedance and
large current gain, but there is almost no
amplification in the amplitude of the voltage output, that is, the output voltage is close to the input voltage. Due to the high
input impedance, the output Due to its low impedance characteristics and load carrying capability, it can also be used as an impedance converter.
- What is the difference between MOSFET and BJT? Which one is better between MOSFET and BJT?
- What is the function of a voltage regulator in a circuit? How to connect a voltage regulator?
- Symbol/working principle/type/characteristics/application scenarios of depletion-mode MOSFET
- What does a rectifier do? What is the process of rectification?
- In-depth analysis of energy losses in oscillation frequencies
- FPGA Features and Architecture
- Share a Motorola amplifier circuit
- Build a musical fountain using Arduino and sound sensor
- What is the difference between JFET and MOSFET
- LED lights that “drain” battery power
- Fish pond oxygenation reminder circuit
- Fish farming thermostatic control circuit
- Biogas concentration detection line
- Proportional frequency discriminator circuit
- Diode square rate detection circuit
- Audio function generator composed of ICL8038
- Parallel crystal oscillator
- Multi-frequency resonant high-frequency power amplifier circuit for transmitter stage
- Fault signal trip circuit
- Digital stopwatch display circuit
