Single-junction transistor trigger circuit 2 that is not affected by power grid fluctuations
Source: InternetPublisher:张小哥 Keywords: Single junction transistor power grid trigger circuit switch Updated: 2021/06/30
In the figure, the 555 time base integrated circuit Ai plays the role of a zero-volt switch . Adjusting the potentiometer
RP can change the phase shift angle of the output pulse usc.
- Current output characteristics of brushed motor driver chips. How to increase the peak drive current?
- Car ice warning circuit sharing
- Design of an autonomous plant watering system using ATtiny85
- Replace the GE LOGIQ a200 ultrasound measurement key with a self-made touch switch
- Star-delta step-down starting control circuit for squirrel cage asynchronous motor
- Using P110C to control 6 DC motors simultaneously
- Add one more component to improve the phase failure protection function
- Temperature control circuit design and analysis
- Design and analysis of a four-bit remote control component capable of remote reset
- Amplitude and phase detection leakage protection device designed and manufactured using PIC16C711A
- Diode Balanced Mixer Circuit
- Principle circuit of current switching class D amplifier
- Timer circuit for blasting
- Forgotten money alarm circuit
- Driver drowsiness alarm circuit
- Instantaneous water heater automatic constant temperature experimental circuit diagram
- Loopback comparator circuit
- Phase-shift trigger circuit of single-junction transistor a
- One of the single-junction transistor trigger circuits that is not affected by power grid fluctuations
- Capacitor step-down unijunction transistor trigger circuit
