Lights out method and merging line a
Source: InternetPublisher:qoistoochee128 Keywords: line generator BSP Updated: 2021/02/05
Combining the electricity from one generator
with the electricity from other generators (or grid system) to achieve
joint operation is called parallel (or grid-connected) operation. Before the generators are put into parallel operation, they must meet
four conditions: the same phase sequence, the same or similar voltage, the same or similar frequency, and the same voltage phase.
The light extinguishing method is also called the dark light method, which is a quasi-synchronous method. The circuit is shown in Figure 7-4. It uses three sets of light bulbs to indicate the frequency and phase sequence of
the two generators .
- How to build a simple tachometer using an infrared reflectance sensor
- Controlling LEDs with Multithreading via Dual-Core Programming on Raspberry Pi using MicroPython
- How to Build a Gesture-Controlled Elevator Prototype Using Arduino Nano
- DIY an electromagnetic levitation device
- An automated model railroad layout project using a microcontroller
- DC motor drive circuit composed of L293D
- Star-delta step-down starting control circuit for squirrel cage asynchronous motor
- Design and analysis of wire control circuit
- Design and analysis of touch delay switch circuit composed of CD4011 and CD4001
- Precious home appliance anti-theft alarm
- Set timing circuit when power is on
- Self-defense anti-riot circuit
- Physiotherapy ventilator circuit
- Farmland drainage automatic control circuit
- Electrical schematic diagram of DC voltmeter input at non-inverting terminal
- Diode Balanced Mixer Circuit
- Integrated synchronous detector composed of analog multiplier MC1596
- superheterodyne radio circuit
- color discrimination circuit
- Motorcycle flash light circuit
