One of the inverter circuits
Source: InternetPublisher:jikai233 Keywords: inverter circuit switch Updated: 2020/11/26
It is a high-frequency transistor inverter circuit that can convert 24V DC power into 1kHz and
1lov AC power. After rectification, it sends out 11OV DC for incandescent lamp use. The output power is about 400W, the efficiency is 85%, and the no-load
loss is about 50w. When the inverter is in use, if the output terminal is short-circuited, it will automatically stop working. After the fault is eliminated, it can work again by closing the switch
again .
- Experiment on realizing photoelectric alarm using photosensitive devices
- Digital level display (CD40147, CD4511)
- IR2153 emergency fluorescent lamp circuit diagram
- Musical doorbell without buttons
- Solar battery and charging circuit
- Driving circuit for driving light-emitting diodes by IR53HD420
- Electronic massage and acupuncture device circuit
- Resistor value selection circuit
- Motor speed photoelectric control circuit
- WT8089 holiday lights ASIC
- Three primary color display circuit
- Forgotten money alarm circuit
- 8-way switching input interface circuit
- Electric shock debounce circuit
- Mechanical electric shock switch value conversion circuit c
- Mechanical electric shock switch value conversion circuit a
- Timer circuit for blasting
- Single pulse signal generating circuit f
- Internal functional block diagram of MAX8775
- Simple magnetizer circuit 2
