Thyristor overcurrent protection circuit
Source: InternetPublisher:兰博 Keywords: Protection circuit thyristor overcurrent protection BSP Updated: 2020/06/12
When starting, press
the lock button SBi once. After the start is completed (
after the motor speed is stable), press SBi again, and
then the protection circuit will be put into work. For
motors with a short starting time (such as a few seconds), SBi can also use ordinary
buttons, as long as the SBi is pressed during the starting process
When the motor is running normally,
the secondary induced potential of current transformers TAi~TA3 is small and is not
enough to trigger the thyristor V.
- What is a RADAX motor?
- Introduction to the internal structure of the Delta winding motor
- Squirrel cage asynchronous motor reverse braking control circuit
- Controlling stepper motors with wireless remote control transceiver and PE-51 board
- Design and analysis of wire control circuit
- IGBT modules block overcurrent by controlling the gate
- Temperature control circuit design and analysis
- Electric vehicle battery charging protection circuit
- Design and production of no-load automatic power-off device for household power supply
- Homemade anti-theft watchdog
- Self-defense anti-riot circuit
- Electronic thermometer circuit
- Peanut and melon seeds roasting machine circuit
- Double detuned loop frequency discriminator circuit
- Common emitter-common base wideband amplifier circuit composed of F733 integrated amplifier
- Voltage series negative feedback amplifier circuit
- Voltage controlled power supply second-order high-pass filter circuit
- Digital stopwatch display circuit
- Small current generator circuit
- Sawtooth wave generator circuit (2)
