One of the zero sequence voltage phase failure protection circuits
Source: InternetPublisher:风向西瓜 Keywords: Protection circuit phase failure protection motor Updated: 2020/04/04
The zero-sequence voltage (current) phase failure protection wire is
a phase failure protection circuit designed based on the phenomenon that the midpoint voltage of the motor winding shifts when one phase of the motor power supply is missing . The circuit is shown in Figure 4-33. It uses a linkage button to better prevent
malfunctions caused
by inconsistent actions of the three main contacts of the contactor when the motor is started . When the power supply loses phase, the relay KA is closed, the contactor KM is released, and the motor
starts to rotate.
- Model rocket launch controller circuit
- How to remotely control devices using ESP8266 and LPC2148
- Peripheral circuit of automotive motor controller power supply chip
- What is a RADAX motor?
- How to set up a cheap beam break sensor control distance scene using a reflector
- Working principle of one Xipu STR soft starter controlling two motors
- Star-delta step-down starting control circuit for squirrel cage asynchronous motor
- Design and analysis of voice control circuit
- Design and manufacture of three-phase motor protection circuit
- Car audio system anti-theft circuit
- Capacitive Neutral Leakage Protection Circuit
- Relay fixed time overcurrent protection circuit b
- Single-phase protection circuit for high-voltage motors
- High voltage automatic protection circuit
- Three-phase motor overcurrent protection circuit
- Structure and working principle diagram of various protection circuits e
- One of the regulated power supply overcurrent protection circuits
- Thyristor overcurrent protection circuit 4
- Generator longitudinal differential protection circuit with fast saturation converter
- Generator longitudinal differential protection circuit b
