兰博
【Chang'an University】Roller measuring device-Han Yonglin
1. Basic requirements (1) Horizontal measurement. Placing the drum horizontally indicates whether the drum is currently in a horizontal position. (2) Inclination measurement. Place the drum on a flat surface and lift one end of the drum to display the tilt angle of the drum. The required error is ≤1°. (3) Rolling measurement. Place the roller on a flat surface and push the roller forward to display the rolling distance of the roller (the rolling range is 100~200cm), and the required error is ≤2cm. 2. Play part (1) horizontal rotation measurement. Twist the drum forcefully on a flat surface. After the rotation stops, the number of complete turns will be displayed. The required number of turns error is ≤ 1 turn. (2) Measuring the height of the inclined plate. Place the roller on the inclined plate (the inclination angle of the inclined plate ranges from 5° to 15°). The roller rolls down freely from the inclined plate. After rolling out of the inclined plate, grab the roller with your hand and stop it. At this time, the roller measuring device makes a sound. Alarm and display the height of the roller on the inclined plate. The height error is required to be ≤3mm. (3) Others.
参考设计图片
Search Datasheet?
Forum More
Update:2025-08-04 19:41:51
