newlandmark
Loli third generation remote control Xiaomi version
1. Open source address : https://www.moz8.com/thread-142710-1-1.html
     The power supply uses a 1S parallel lithium battery ( note the positive and negative poles of the battery interface pins ) , so the chip uses STC12LE5A60S2
     The screen is a 0.96-inch OLED of the 7P.
      The thickness of the proofing board is 1.2mm (the shell will not cover if it is too thick)
2. 1A lithium battery TP4056 charging and protection solution
  (It is the lithium battery TP4056 charging protection module on a certain product. The materials are directly appropriated and cheap.
      Features, parameters and usage methods (please refer to a treasure)
3. The remote control uses a mechanical switch, which is simple and practical. The power button of the remote control is the menu button + power indicator light, and the two buttons on the back are fine adjustment + and fine adjustment -
4. Wireless module Yibit or Zeyao’s nRF24L01 wireless module patch
5. The micro USB on the remote control is the charging port, and the USB port is the microcontroller program download port. You can use the data cable to DIY a download cable for connecting to the CH340 downloader.
   The CH340 downloader only needs to connect the three lines of TX, RX, and GND, and download through the power switch of the remote control.
参考设计图片
Search Datasheet?
Forum More
Update:2025-08-06 09:01:37
