super_star
VL53L0X ranging module
VL53L0X is a new generation of time-of-flight (ToF) laser ranging module (different from traditional technology). It adopts the smallest package currently on the market and can provide accurate distance measurement regardless of the target reflectivity. It can measure absolute distances up to 2m, setting a new benchmark for ranging performance levels and opening the door to a variety of new applications. The VL53L0X integrates a leading SPAD array (Single Photon Avalanche Diode) and embeds ST’s second-generation FlightSense™ patented technology. The VL53L0X's 940nm VCSEL emitter (vertical cavity surface emitting laser) is completely invisible to the human eye. Coupled with the built-in physical infrared filter, it has a longer ranging distance, stronger immunity to ambient light, and is resistant to cover sheets. The optical crosstalk has better stability.
Default IIC address: 0x52
  • Fully integrated small form factor module
    • 940 nm laser VCSEL
    • VCSEL driver
    • Ranging sensor with embedded advanced microcontroller
    • 4.4 x 2.4 x 1.0mm
  • Fast and accurate ranging
    • Measured absolute distance up to 2m
    • Reported distance is independent of target reflectivity
    • Advanced embedded optical crosstalk compensation simplifies cover glass selection
  • eye safety
    • Class 1 laser device, complying with the requirements of the latest standard IEC 60825-1:2014 (3rd edition)
  • Easy to integrate
    • Single reflow component
    • No additional optical components
    • single power supply
    • I2C interface for device control and data transfer
    • Xshutdown (reset) and interrupt GPIO
    • Programmable I2C address
参考设计图片
Search Datasheet?
Forum More
Update:2025-08-08 00:19:52
