elleny
[Professional Edition Tutorial] Lighting Control System
1. Engineering background
      How to use and learn Lichuang EDA Professional Edition? Why does EasyEDA launch the professional version? What are the advantages of the professional version? How to better use the professional version of EasyEDA for design. This project will take you step by step to use the professional version. This case uses the lighting control system case as the background and takes you from the creation and management of the device library, schematic rule setting and design, PCB rules and layout design, 3D printing, panel Export and use design (not updated) and production files. Learn more about the functions and features of Lichuang EDA Professional Edition.
     First, I will bring you the instructional video link of Lichuang EDA Professional Edition: https://www.bilibili.com/video/BV1UF41147Fx
Please read below for the text version of the introduction:
2. Introduction to Professional Edition
      Compared with the standard version, the professional version can achieve 30,000 devices without lag, is very smooth, and has more rigorous design constraints and design processes. It is mainly aimed at professional PCB design engineers and complex circuit designs. Currently, the professional version also supports client downloads, including the following modes:
Full online mode: login required, libraries and projects are stored in the cloud, supports collaboration, and supports automatic backup of cloud projects to local;
Semi-offline mode: no login required, libraries and projects are stored locally, collaboration is not supported, and cloud system libraries are supported. This mode is recommended.
Full offline mode: no login is required, libraries and projects are stored locally, collaboration is not supported, and the use of cloud system libraries is not supported. Built-in 1w+ commonly used system libraries.
Click to download the client: https://lceda.cn/page/download
Professional version development history:
  1. In 2020, the design framework will be reconstructed based on the standard version and Lichuang EDA Professional Edition will be launched to solve the problem of large PCB jamming.
  2. In 2021, in order to adapt to applications in various scenarios, a fully offline version will be launched, and 3D shell design and panel design functions will be added.
  3. In 2022, the professional version product performance will be further improved, and a color silk screen design will be launched to make your PCB full of color. The enterprise privatized version will be available soon.
Introduction to the special features of the professional version:
  • Massive component library
    • Method 1: Shift+F component library search pop-up window
    • Method 2: Shortcut key S to display or hide the bottom component library dialog box
    • Method 3: Commonly used library settings on the left
  • Project-based architecture
  • Perfect design rules
  • Reuse tile settings
  • 3D modeling capabilities
  • Panel design features
  • More features
Professional version function preview: Color silk screen, let colorful black embellish your personalized PCB
3. Schematic design part
  • Creation of component library
    • Creation of Chip Resistors
    • Creation of Type C connector
  • Create a personal component library
    • Online browser version personal commonly used library
    • Offline client version personal library creation
  • Project creation and page settings
  • Reuse block (hierarchical schematic) design
  • Practical explanation of component selection and schematic diagram
  • Schematic arrangement and design inspection
4. PCB design part
  • PCB rule settings
  • PCB layout explanation
  • PCB wiring practical explanation (with function introduction)
  • PCB design optimization and inspection
5. Export of production files
  • Bill of Materials BOM
  • PCB manufacturing Gerber files
  • coordinate file
  • Netlist export
  • Attachment: Import and export of AD and other software
6. Features
(1) 3D shell design function
  • Introduction to real-time preview and filtering
  • Shell border settings
  • Screw hole placement
  • Side opening instructions
  • Introduction to top and bottom openings
  • Export and production of 3D files
More functions are being added one after another. . .
参考设计图片
Search Datasheet?
Forum More
Update:2025-08-04 00:23:13
