super_star
Power port adapter board with several commonly used ports
Power port adapter board with several commonly used ports, divided into upper and lower channels, each with DC5.5mm interface, KF301-5.0-2P, positive and negative 4Pin pin headers, positive and negative 2pin female headers, XH2.54-2P terminal . There are positive and negative 2-pin headers in the middle for connecting the upper and lower circuits as positive and negative power supplies. Among them, the area of ​​the lower road is slightly larger and the current carrying capacity is slightly larger. There is also a RAD-0.1 packaged capacitor for filtering, which is optional. Each has 1206 LED indicators.
BOM download
Schematic_Power port adapter board with several common ports_2022-10-08.pdf
SCH_Power port adapter board with several common ports_2022-10-08.json
Sheet_1_2022-10-08.schdoc
PCB_PCB_Power adapter_2_2022-10-08.pdf
PCB_PCB_Power adapter_2_2022-10-08.json
Gerber_PCB_Power adapter_2_2022-10-08.zip
60977
electronic
参考设计图片
Search Datasheet?
Forum More
Update:2025-08-05 07:00:22
