BaaJ9
stc-camp2024
Introduction:
The STC32G series microcontrollers are 32-bit 8051 microcontrollers designed for superior anti-interference, ultra-low cost, high speed, and low power consumption. At the same operating frequency, the STC32G series is up to 70 times faster than traditional 8051 microcontrollers. This demonstrates the exceptional performance of STC's 32-bit microcontrollers.
System Functions:
The STC32G12K128-35I-LQFP48 minimum system board uses USB mode for ISP downloading.
Onboard Resources
: Main Control Chip: STC32G12K128, LQFP-48 surface mount package
. Power Connection: Powered via one Type-C port or connected to a computer for program downloading.
LED Display: One power indicator light
. Button Control: One normally closed switch for cold start downloading, one independent button with interrupt function.
Program Expansion: External M24C20 EEPROM chip via IIC interface
. Pin Header: All chip pins are brought out, compatible with the pin arrangements of other mainstream microcontroller core boards.
Reference voltage source: The TL431 reference voltage source is used to provide a stable 2.5V reference voltage for the microcontroller.
参考设计图片
Search Datasheet?
Forum More
Update:2026-03-27 13:03:13
  • Introduction to CPU DIY
  • I have a question about DirectX.
  • Characteristics and Applications of Diodes
  • vxworks input and output problem!
  • Urgent!!!! Please help me! ! ! ! Float data display problem
  • 51 Embedded System Tutorial
