Four-level water level indicator with full water alarm function
Source: InternetPublisher:宋元浩 Keywords: Water level indicator Updated: 2024/06/13
working principle
The circuit is composed of a quad bidirectional analog switch integrated circuit CD4066 as the core. Each circuit has four independent switches that can control the transmission of digital or analog signals. When there is no water in the water tank, due to the effect of the 180K resistor, the control ends of the four switches are low, the switches are disconnected, and the LED does not light up. As the water level increases, due to the conductive properties of water, the 13th pin of the IC is high, S1 is turned on, and LED1 lights up. When the water level gradually increases, the LEDs light up in turn to indicate the water level. When the water is full, LED4 lights up, indicating that the water is full. At the same time, T1 is turned on, and B sounds an alarm, indicating that the water is full. When the alarm is not needed, just disconnect switch K.
![Four-level water level indicator with full water alarm function](https://www.eeworld.com.cn/circuit/upload/202301/4/d881933415c23ec05f1768b0976794f48bb892c5.gif)
- Advantages and Disadvantages of Negative Feedback Circuits, Analysis of Operational Amplifier Feedback Circuits
- Does lithium iron phosphate battery need a protection board? The correct way to charge lithium iron phosphate battery
- Voltage divider circuit calculation formula, where to find the voltage divider circuit?
- How to identify common mode interference? Methods to eliminate common mode interference
- What are the main types of resistors? Detailed explanation of the functions and uses of resistors
- What are the types of commonly used batteries?
- How to calculate the value of capacitors in parallel?
- What is a D flip-flop and how does it work?
- DIY a decorative lamp
- Experiment and production of NE555 time base integrated circuit
- Water level indicator circuit diagram
- 555 square wave oscillation circuit
- 555 photo exposure timer circuit diagram
- Introducing the CD4013 washing machine timer circuit diagram
- Simple level conversion circuit diagram
- 555 electronic guide speaker circuit diagram for blind people
- Circuit diagram of disconnection alarm composed of 555
- Analog circuit corrector circuit diagram
- color discrimination circuit
