Drive an N-channel MOSFET with a microcontroller
Source: InternetPublisher:Zi1HYSH Keywords: Microcontroller MOSFET Updated: 2025/12/16
Drive N-channel MOSFETs and microcontrollers
MOSFET transistors are an excellent choice for driving high-current devices such as motors or high-power RGB LEDs. Compared to bipolar transistors, they offer very low switching resistance and very low heat dissipation. This guide aims to explain how to drive N-channel MOSFETs using a microcontroller such as a PIC or ATMEGA. Transistors generate heat when driving large loads because of the voltage drop (Vce) across them, and heat (watts) = voltage * current. This can lead to thermal runaway within the transistor, which, if not handled carefully, can ultimately damage the device.
A FET (Field-Electronic Field-Controlled Transistor) acts like a digital switch, capable of turning on and off between its drain and source terminals by adjusting the voltage potential at its gate. When an FET is on, it typically has a resistance of less than 0.01 ohms; when off, it functions like an open circuit. Due to its low resistance in the on-state, an FET can carry large currents without generating heat.
FETs are turned on by voltage potential, not current, so they have very high input impedance. Because of this, you only need a single voltage to turn them on, making them ideal for digital electronic devices.
Have you ever considered using a FET (Field-Electronic Field Test) to switch a target device instead of a transistor? If not, then you should read on, as FETs offer many advantages over transistors. The pin arrangement of an FET is similar to that of a transistor; consider the following analogy:
Transistor FET
Collector Drain
Base Gate
Emitter Source
Similar to transistors, there are two types of FETs: N-channel and P-channel. Depending on your application, you will need to choose the appropriate one. N-channel FETs are best used when switching the FET to ground because no drive circuitry is required—even if the target supply voltage is higher than the gate logic voltage. If you want to control the supply voltage of the target device, please refer to the P-channel MOSFET guide. Consider the following circuit: (Note that only the gate voltage is needed, not the current as in a transistor):
Example of an N-channel MOSFET
The circuit described above is an example of how to drive a motor using an N-channel FET. When driving an inductive load, a reverse-biased diode connected in parallel with the motor should be used, but this is not necessary for a purely resistive load.
One of the biggest advantages of FETs is their huge input impedance, but this must be handled carefully. If the gate is not grounded, it may float high. This isn't a problem when the microcontroller is on and the output is configured in one of two states (high, 5V or low, 0V)—but it's a major issue when the microcontroller is off or on. In the diagram below, the switch isolates the gate, similar to what would happen if the control pin were set to an input with several megaohms of impedance (note that the FET doesn't turn off):
FET floating
To correct this, place a resistor (10K or higher) at the gate and ground the FET:
FET ground
I haven't delved into any specific FET models yet; I'm just covering the basics. There are different types of FETs available, but most require high Vgs voltages to operate. For microcontrollers, logic-level MOSFETs are preferable because they don't require driver circuitry to switch high voltages. They can be driven directly from 5 volts, and some even as low as 3 volts.
Among hundreds of different N-channel logic level MOSFETs, I used the following models:
STP36NF06L
Finally, please remember that FETs are very sensitive to static electricity, so handle them with care. However, I haven't damaged one yet in my "amateur" work.
- PIC16F84 Alarm Clock
- Using ATMEL AVR combination lock
- AVR Thermometer TCN77
- Tutorial on using 8051 microcontroller to display content on LCD screen
- Introduction to MCU GPIO Interface
- What are the functions of microcontrollers for IoT?
- What is the basic structure of a microcontroller?
- What is the difference between RISC-V, ARM and x86 microprocessors?
- Commonly used MCU reset circuit sharing
- Working principle of DCC module, practical application and precautions of DCC module
- Design and production of three-way sectional switch based on AT89C2051 microcontroller
- Microcontroller control circuit
- Interface circuit design of SPCE061A microcontroller and fingerprint identification module
- Minimum system interface circuit based on AT89C52 microcontroller
- Car window control circuit
- JFET-MOSFET headphone circuit diagram
- MOSFET resonant DC-DC power supply circuit
- The interface between DAC1231 and microcontroller 8031
- Game console using SMC624A microcontroller
京公网安备 11010802033920号
