T-121 temperature sensor constitutes temperature control circuit diagram
Source: InternetPublisher:风向西瓜 Keywords: Temperature sensor temperature control circuit control circuit diagram Schmidt Updated: 2020/09/08
The control temperature point can be preset by adjusting RP1 and RP2. The 555 time base circuit constitutes a Schmidt inverter circuit, and the relay is used to realize automatic control of the equipment. The T-121 temperature sensor constitutes a temperature control circuit as shown in the figure below:
- What is a photocoupler and how to select and use one?
- The unidirectional conduction current of the diode, the diode and its common uses
- What is the difference between MOSFET and BJT? Which one is better between MOSFET and BJT?
- The Importance and Ideal Model of Impedance Matching
- RC filter explained in detail
- DIY a decorative lamp
- Beautiful crown wreath made with LED
- Structural diagram and function of sliding resistor
- Touch circuit design and analysis
- Circuit diagram of a differential amplifier circuit
- Schmidt humidity sensor
- DC motor follow-up control circuit diagram
- 555 dream lantern control circuit diagram
- Infrared thermometer control circuit diagram
- Backup power control circuit diagram
- Schmidt shaping circuit
- Simple thyristor temperature automatic control circuit diagram
- Start-stop control circuit diagram that can send start signal
- Contactor interlocking forward and reverse control circuit diagram
- Ringing transmission and writing control circuit diagram
