555 linear audio frequency meter circuit diagram
Source: InternetPublisher:MartinFowler Keywords: circuit diagram audio frequency meter Updated: 2020/01/09
The frequency meter includes pulse amplification shaping, differential, monostable, average circuit and meter indication, and is used forfrequency measurement of unknown frequency signals within the audio range.
After VT1 and VT2 amplify and limit the signal to be measured, and after differentiation by C2 and R2, trigger a monostable circuit composed of 555, R3, and C3. The temporary stabilization time td=1.1R3C3. Different frequency ranges can be selected by selecting different The principle is that the transient settling time of the monostable state should be smaller than the period of the signal to be measured. R4 and C1 are filter networks, the purpose is to take out the average value suitable for the meter indication, and add it to the 50uA meter after being limited by R5.
- Voltage divider circuit calculation formula, where to find the voltage divider circuit?
- The Importance and Ideal Model of Impedance Matching
- Types and structures/characteristics/functions/implementations of smart sensors
- What is power factor and three ways to improve it
- Causes of PCB deformation How to prevent circuit board bending and warping
- How to build a drag racing timer circuit using a 7-segment display and discrete components
- Tutorial on building a NOT gate using BJT transistors
- What is the difference between JFET and MOSFET
- Simple LED advertising light circuit
- Circuit diagram of a differential amplifier circuit
- Common double-tube energy-saving lamp circuit schematic diagram
- LM567 decoding alarm circuit diagram
- 555 photo exposure timer circuit diagram
- Inspection circuit diagram for broken rotor bar of three-phase motor
- Bus stop indicator circuit diagram
- Car power supply voltage monitoring circuit diagram
- AC grid powered light emitting diode circuit diagram
- Hitachi RAS-5102 inverter air conditioner remote control transmitter circuit diagram
- Programmable multi-compound fast charging circuit diagram
- Remote control detector circuit diagram
