Pillow school circuit-3
Source: InternetPublisher:国民男神经 Updated: 2013/02/26
Models using this pillow calibration circuit include: Korean Samsung MC-15 movement, Venus C6418, V6458, Peony 64C1, Leroy CT6388W, etc.
The field sawtooth wave voltage is sent to the pillow calibration circuit through pin (4) of P404. R455, C454, and R457 form an integrating circuit to integrate the field sawtooth wave to form an upward convex parabolic wave voltage, which is added to B of the parabolic wave shaping amplifier tube Q451. pole, after amplification and shaping, a concave parabolic wave voltage of 9V (peak-to-peak value) is output from the C pole, and then added to The B pole of the composite tube composed of Q453 and Q452 is amplified and outputs a parabolic wave voltage of 12.5V (peak-to-peak value) from the C pole of Q452. Finally, it is sent to the row scanning circuit through the (3) pin of FR459 and P403. Scan current modulation. Achieve the purpose of correcting pincushion distortion.
VR451 is the line width adjustment potentiometer, and VR452 is the pincushion distortion adjustment potentiometer.
- How does a series arrangement of Zener diodes affect the electrical behavior?
- How to identify common mode interference? Methods to eliminate common mode interference
- Principle set of zero-crossing detection circuit advantages and disadvantages
- This article will tell you the hard requirements of operational amplifiers
- DIY a decorative lamp
- TL494 pin functions/configuration/ratings/operating conditions/layout diagram
- Why use PWM? What are its advantages?
- Make a flameless electronic candle using simple electronics and LEDs
- Summary of knowledge points of multiplexer
- Circuit diagram of a differential amplifier circuit
- 555 square wave oscillation circuit
- 555 photo exposure timer circuit diagram
- Introducing the CD4013 washing machine timer circuit diagram
- Simple level conversion circuit diagram
- 555 electronic guide speaker circuit diagram for blind people
- Circuit diagram of disconnection alarm composed of 555
- Analog circuit corrector circuit diagram
- color discrimination circuit
- Color sensor amplification circuit
- Level indication circuit
