Universal digitally controlled offset adjustment circuit for op amps
Source: InternetPublisher:MartinFowler Keywords: Offset Adjustment Op Amp Updated: 2024/09/09
As shown in the figure, this is a general digital control offset adjustment circuit. The offset change is digitally controlled. The integrated chip DAC-08C is used as a 6-bit D/A converter. Pins ② and ④ are output terminals, and two l00kΩ resistors are connected externally. These two resistors are equivalent to load resistors, on which an output voltage Vo1 is generated. The output voltage Vo1 is converted into an offset adjustment current of A2 through two 4.7MΩ large resistors. The two 4.7MΩ resistors are determined according to the range of offset adjustment required. This circuit is very useful for large circuit systems, because in fact any offset voltage can be stored in the memory and added to the amplifier when needed.
- What is a quartz crystal? Quartz crystal equivalent circuit analysis
- How do pull-up resistors work? How do I choose a pull-up resistor value?
- Why do we need a MOSFET gate resistor? MOSFET Gate Resistor Placement
- An article explains the working principle of the Wheatstone bridge
- What is an ac to dc transformer in circuit design
- What is the difference between CPLD and FPGA?
- Basic characteristics/working principles and application circuits of tunnel diodes
- Share an interesting LED decoration project
- Introduction of TDA4863J/4863AJ TV field scanning IC
- Simple LED advertising light circuit
- Thermometer circuit with temperature compensation
- Try making SRS effector circuit diagram using op amp
- Bandpass filter circuit composed of single power supply op amp 8FC7
- Actual circuit diagram of switching power supply composed of four op amps
- Forward/reverse circuit composed of power op amp
- Positive and negative reference voltage source circuit diagram using op amp
- Adjustable current source circuit diagram using op amp
- Constant voltage and constant current circuit diagram controlled by op amp CA3240
- Motor rotation detection circuit using op amp
- Server preamplifier circuit diagram using parallel operational amplifier
