RIAA phono equalizer amplifier circuit composed of OPA27
Source: InternetPublisher:拳制龙 Keywords: Amplifier Circuit Updated: 2024/09/09
The figure below shows an RIAA phono equalizer amplifier composed of OPA27. Rl~R3, Cl, and C2 in the negative feedback loop are used to form the three inflection point time constants of 3180, 318, and 75μs in the RIAA equalizer curve. The RC network selected by switch S1 at the output can filter out the shaking noise component of the turntable.
- Voltage divider circuit calculation formula, where to find the voltage divider circuit?
- Ideal characteristics of operational amplifiers/pin configurations/gain types/primary applications
- How to read resistor color codes? Resistor color codes illustrated
- How do you calculate the value of capacitors in series? Why use capacitors in series?
- How to build a triangle wave generator using an op amp and discrete components
- What types of force sensors are there?
- Touch circuit design and analysis
- Make a simple AM radio with digital circuit
- Experiment and production of NE555 time base integrated circuit
- Common electrical circuits: frequency-selective (bandpass) amplifier circuit
- Isolated 4 to 20mA-RTD transmission amplifier circuit
- Gyro amplifier circuit
- Practical amplifier circuit c composed of operational amplifier LM386
- Common high input impedance buffer amplifier circuit
- The working principle of common collector amplifier circuit
- Three amplification circuits of junction field effect transistors - common gate
- Differential amplifier circuit
- Common drain amplifier circuit
- Added neutralizing capacitor tuning amplifier circuit
- A co-located stereo amplifier circuit powered by positive and negative symmetrical power supplies
