Brightness adjustment circuit using gate-controlled switch
Source: InternetPublisher:抄写员 Keywords: Sensors switches CMOS circuits Updated: 2024/09/03
The brightness adjustment circuit using gate switch is shown in the figure. This circuit has the following characteristics: First, a CMOS gate circuit is used to control the on and off of the LX1970 power supply. The LX1970 is powered on only when the output of the gate circuit is high. Since the LX1970 is a micro-power device, the power supply voltage can be provided by the gate circuit; second, an isolation diode (VD) is connected in series at the SRC end. When the LX1970 is powered off, VD is cut off, which can play an isolation role, so that the brightness signal cannot be added to the LX1970, which can play a protective role; third, the 3.3V DC voltage signal and the PWM signal can be equivalent to the two input signals of the logic OR gate. Therefore, changing the DC voltage can also adjust the brightness. VD can choose 1N4148 high-speed switch silicon diode.
- How to use a microcontroller to control a servo motor?
- Model rocket launch controller circuit
- How to Make a Simple 2-Step Arduino Programmable Timer Circuit
- Controlling LEDs with Node-RED in Raspberry Pi
- An automated model railroad layout project using a microcontroller
- Light-controlled circuit design and analysis
- Simple three-phase motor phase loss protection circuit
- Design and production of no-load automatic power-off device for household power supply
- Homemade short circuit alarm device
- Infrared detection alarm
- High-resolution 35 mm CCD image sensor, did you know?
- X-Class CMOS sensor, do you know it?
- How the acceleration sensor works
- Car ignition circuit diagram based on FM484 magnetic induction
- Accurately identify three primary color circuits
- Sensor adjustment circuit diagram
- Hall switch integrated sensor characteristic curve circuit diagram
- Sensor amplification circuit diagram
- Basic connection diagram of bridge sensor and XTR104 02
- Sensor analog signal input ADC701/SHC702 circuit
