Switch signal generation circuit
Source: InternetPublisher:萌面大虾 Keywords: switching signal signal generation BSP Updated: 2020/06/24
Shown is a switching signal generating circuit . As can be seen from the figure, it is composed of two inverters. Pressing the switch SW1
can output a pulse, which can avoid the interference pulse generated when the switch jitters.
When SW1 is closed instantaneously, the voltage on tcl causes the output of inverter A to jump once, and the positive feedback of the inverter produces alternative "high" and
"low" level changes. R. Delays the charging and discharging process of cl, which makes the output not affected by contact jitter.
- Analysis of the flow direction of transistor current
- What factors are related to the hysteresis loss of the transformer? Can the hysteresis loss be reduced?
- In-depth analysis of energy losses in oscillation frequencies
- What are the classifications of filters?
- RC filter explained in detail
- Datasheet/Pinout/Technical Specifications of LMC555
- Working principle and truth table of JK flip-flop
- TL494 pin functions/configuration/ratings/operating conditions/layout diagram
- Why use PWM? What are its advantages?
- How to build a triangle wave generator using an op amp and discrete components
- electromagnetic field sensor
- Particle clogging alarm circuit of wheat seeder
- Egg heating control circuit
- Electrical schematic diagram of DC voltmeter input at non-inverting terminal
- Junction field effect transistor mixer circuit
- Double detuned loop frequency discriminator circuit
- Schiller oscillator circuit
- Differential Amplifier Circuit
- Voltage-controlled voltage source second-order band-pass filter circuit
- Three primary color display circuit
