The working principle of common emitter amplifier circuitb
Source: InternetPublisher:sigma Keywords: Common emitter amplifier circuit output voltage Updated: 2020/06/04
After the signal passes through the common emitter amplification unit circuit, it outputs an inverse amplified signal. Its working principle is shown in the figure. When analyzing, we
can consider the change curve of the input signal as the change curve of the input current . In the 1/4 cycle, the current is increasing. According to
the amplification function of the transistor IC-18IB, it can be seen that the current is also increasing. According to Ohm's law URC=ICRC, seven f. Then URC f, then from the output voltage
UR
on the load RL , = VCC-URC can be obtained·sevent, URC t, Vcc remains unchanged, Uk, J. That is, the output curve is as shown in Figure 1-7 (a)
. The other cycles are similarly shown in Figure (b) (c) (d). It can be seen that the output voltage is opposite in phase to the input voltage.
- Analysis of the flow direction of transistor current
- An article explains the working principle of the Wheatstone bridge
- What is an ac to dc transformer in circuit design
- What factors are related to the hysteresis loss of the transformer? Can the hysteresis loss be reduced?
- Capacitance detection circuit configuration, how to deal with low frequency and high frequency noise?
- Working principle and truth table of JK flip-flop
- How to Build a Simple Temperature Indicator Circuit Using NTC and PTC Thermistors
- Why use PWM? What are its advantages?
- How to install the accelerometer
- What is the difference between high-side and low-side resistive current sensing
- TMPO1 internal functional block diagram and basic application circuit
- AN6071 application circuit b
- Series DC regulated power supply
- Industrial static elimination circuit
- The working principle of common emitter amplifier circuit a
- Charging circuit using transformer step-down method
- Output voltage expansion circuite
- Stabilized power supply with continuously adjustable output voltage
- Applications to increase output voltage (b)
- Ultra-low quiescent current ZXSC100 application circuit analysis
