LED emergency lighting
Source: InternetPublisher:fish001 Keywords: CD4081 LED circuit Updated: 2024/08/26
The emergency lighting introduced here can be powered by a rechargeable battery (such as a 3.6V Ni-cd battery) or a common battery (3.0V CR2032). When the AC power fails, the white LED (LED1) can automatically light up to keep you away from darkness. The quiescent current of the circuit is very small. In fact, the battery will only come in handy when the LED is lit.
Figure 1 shows this emergency lighting circuit. When sunlight falls on the phototransistor T1 (L14F1), T1 is turned on and T2 is turned off, making the output of N1 high. Gates (circuits) N2, N3 and N4 are connected to the output of gate (circuit) N1, and their outputs are still high, resulting in the white light LED not lighting up. In addition, the +5VDC (direct current) jack additional circuit shown in the dotted box in Figure 1 is used to charge the rechargeable battery.
At night, when there is no sunlight falling on the phototransistor T1, T1 is turned off and transistor T2 is turned on, which causes the output of gate N1 to be low level. As a result, the outputs of gates N2, N3 and N4 are also low level, and the white light LED is lit.
- Characteristics and bias of common emitter amplifier, application of common emitter amplifier circuit
- Summing amplifier circuit diagram analysis
- TL783 parameters/pin configuration and functions, tl783 parameter circuit diagram
- Feedback Amplifiers
- What is a FinFET? What are the advantages and disadvantages of FinFET?
- What is the difference between MOSFET and BJT? Which one is better between MOSFET and BJT?
- What is a pure resistance circuit? What is a pure resistance AC circuit?
- How to read resistor color codes? Resistor color codes illustrated
- How does sand become chips?
- What is the difference between CPLD and FPGA?
- simple photometer
- LED cycle lighting circuit controlled by 12C508A
- Capacitor step-down LED drive circuit diagram using varistor
- 8W LED driver application circuit diagram (input voltage is 85 to 264V)
- LED energy-saving lamp circuit principle circuit diagram
- LT3755 driver LED application circuit diagram
- LED light circuit diagram
- LT3783 boost configuration driving LED circuit diagram
- Constant current drive LED circuit based on LM2734
- NCP1200 driver LED circuit
