newrudeman
43 W high power factor constant voltage output flyback converter based on ICL8810
REF_ICL8810_LED_43W_BM
REF_ICL8810_LED_43W_BM This 43 W reference design uses Infineon's high power factor flyback controller ICL8810. The evaluation board is a constant voltage (CV) secondary side regulation (SSR) system designed for use with a constant current (CC) converter for LED lighting applications.
Two-stage topologies are becoming increasingly popular due to the easy scalability of primary-side power and secondary-side characteristics. The REF_ICL8810_LED_43W_BM solution features a plug-and-play design and can be used with the secondary-side DC/DC evaluation board.
As a default, the reference design board is equipped with a depletion mode MOSFET BSS126I based startup circuit on a small adapter board. This setup will significantly reduce standby losses. If low standby power consumption is not required, the startup circuit can be changed to a resistive startup design.
This reference design comes with two conditioning circuits. Both are plug-and-play solutions, but at least one circuit must be connected to the motherboard. There is a cost trade-off between the two evaluation boards; the TL431 evaluation board is lower cost and has good standby performance, while the op amp board exhibits excellent overall performance at the 30 mW power level. With its benchmark power factor correction and total harmonic distortion performance at full and light load conditions, the ICL8800 supports window driver and platform designs. In addition, the IC combines excellent efficiency with low EMI characteristics without compromising light quality.
Feature description
  • Constant Voltage (CV) Secondary Side Regulation (SSR) Reference Design for LED Lighting Applications
  • ICL8810 integrates burst mode to achieve very low standby power of less than 100 mW
  • Power factor (PF) > 0.9 and THD < 10%, applicable to a wide load range (AC input up to 277 V rms )
  • Maximum AC input voltage: 90 – 305 V rms
  • Critical conduction mode and quasi-resonant mode supporting smart valley jumping
Advantage
  • Ideal topology for LED on/off drivers with a minimum dimming level of 5%
  • Can create smart lighting
  • Two-level topology that combines scalability and functionality
  • Super high gloss quality
  • Cost-effective bottom-up design
  • High flexibility, low material cost, suitable for a variety of applications
Potential applications
LED lighting, smart lighting, LED drivers and luminaire
adapters and chargers up to 125 W, flat screen TVs, all-in-one PCs, monitors up to 125 W
参考设计图片
Search Datasheet?
Forum More
Update:2025-08-04 22:01:01
