Novel hybrid BTL amplifier 01
Source: InternetPublisher:ghaytweyhtoo Keywords: power amplifier integrated circuit Updated: 2020/01/23
shown (only one
channel is drawn). vl and V2 form a typical
SRPP preamp circuit, which has a higher gain to compensate for the loss of the signal
caused by
the attenuated tone
circuit behind it . There are two reasons for choosing the attenuated
tone circuit: first, because
the circuit is simple, stable, and does not require debugging; second,
because the attenuated tone circuit will not
cause adverse phase shifts to the original signal, making the final output
signal well positioned. V3 is an inverting stage, outputting two signals
with opposite phases to
drive the BTL power amplifier circuit composed of Icl and 1C2 respectively.
IC1 and IC2 use
the high-performance and high-power integrated circuit LM3886 launched by the National Semiconductor (NS) Company of the United States. , this circuit adopts advanced overvoltage, undervoltage, short
circuit and other protection circuits. A BTL circuit composed of two such power amplifier integrated circuits can
provide a continuous average power of more than 100w for an 8n load under the condition of 30V power supply. .
- What is a photocoupler and how to select and use one?
- What is an ac to dc transformer in circuit design
- Principle set of zero-crossing detection circuit advantages and disadvantages
- What is a D flip-flop and how does it work?
- Working principle/advantages/disadvantages/size of optical fiber
- Basic characteristics/working principles and application circuits of tunnel diodes
- Causes of PCB deformation How to prevent circuit board bending and warping
- Why use PWM? What are its advantages?
- How to build a triangle wave generator using an op amp and discrete components
- What is the difference between high-side and low-side resistive current sensing
- Tube crossover balanced inverter circuit diagram
- TDA1516 two-channel power amplifier
- LM3886 BTL amplifier
- A set of power amplifiers and speakers suitable for MPC
- Production of high-quality active two-way constant current power amplifier 02
- Homemade high-quality integrated amplifier 01
- Upper and lower symmetrical negative feedback mode field effect transistor power amplifier 01
- 70W integrated power amplifier
- Class S power amplifier 02
- Current negative feedback DC power amplifier
