Frequency division circuit diagram of Hall integrated component DN6839
Source: InternetPublisher:toothache Keywords: Frequency dividing circuit circuit diagram Updated: 2021/10/04
As shown in the figure, it is a frequency dividing circuit using Hall integrated component DN6839 . In the circuit, DN6839 is used to detect the pulsation of the magnetic field to obtain the pulse signal waveform, and then divide the pulse signal to obtain the required frequency pulse. This kind of circuit is mostly used in situations where the magnetic field pulsation frequency is very high. Here, TC4013 is used to divide the frequency by 2, and the output signals of terminals A and B can also be used to synthesize pulse waveforms of other frequencies. DN6839 is a switching Hall integrated component, and its output is generally in the form of an open collector, making it easy to interface with MOS integrated circuits. In addition, the allowable current of the open collector is relatively large and can directly drive a load of 10 to 15mA.
- Voltage divider circuit calculation formula, where to find the voltage divider circuit?
- How are diodes made using semiconductors?
- What is a pure resistance circuit? What is a pure resistance AC circuit?
- This article will tell you the hard requirements of operational amplifiers
- How to read resistor color codes? Resistor color codes illustrated
- How does sand become chips?
- Capacitance detection circuit configuration, how to deal with low frequency and high frequency noise?
- Datasheet/Pinout/Technical Specifications of LMC555
- Beautiful crown wreath made with LED
- Summary of knowledge points of multiplexer
- LM567 decoding alarm circuit diagram
- A frequency meter circuit diagram composed of CD4046
- Electronic frostbite treatment device circuit diagram
- Input status indication circuit diagram
- Two smartphone charging circuit diagrams
- Lithium battery fast charger circuit diagram design
- Delayed AGC principle circuit diagram
- Laser flashlight circuit diagram
- Monostable circuit diagram
- Frequency division circuit diagram of Hall integrated component DN6839
