Bridge Measurement - 4 to 20mA Current Transformer
Source: InternetPublisher:公子李 Keywords: bridge converter AD Updated: 2020/05/12
The function of the circuit shown is to amplify the measurement signal of the sensor and convert it into a 4-20mA current output. The
measuring bridge is a bridge sensor, which can be a gas sensor or a pressure sensor; the excitation voltage of the sensor is the IO. OOV reference voltage source of
the AD 694 itself (output from the ⑦ pin), and the sensor output signal is sent to the AD524 for amplification and
output to the buffer amplifier inside the ② and ③ pins of AD 694. After buffer amplification, it is processed by the internal VI converter and other circuits , and finally outputs 4-20mA current
from the ⑩ pin .
- How are diodes made using semiconductors?
- What is a pure resistance circuit? What is a pure resistance AC circuit?
- How to identify common mode interference? Methods to eliminate common mode interference
- Classification and characteristics of operational amplifiers, classification and characteristics of operational amplifiers
- What is power factor and three ways to improve it
- Why use PWM? What are its advantages?
- Important things to know about PCB routing and how to design the right routing for your PCB
- What is the difference between JFET and MOSFET
- What is the difference between high-side and low-side resistive current sensing
- Introduction of TDA4863J/4863AJ TV field scanning IC
- AD7730 digital pressure measurement circuit
- Basic application circuit of AD590d
- AD594 to 597 basic application circuit a
- AD597 functional diagram
- AD574A Unipolar and Bipolar Input Circuitb
- Principle and production of automotive power converter
- Electronic transformer circuit
- AD22057 amplifier circuit
- Using AD586 to generate - 5.000V voltage circuit diagram
- AD590 temperature measurement circuit
