aerobotics
SONOMA (MAXREFDES14#): Isolated Power Measurement Subsystem Reference Design
HD pictures
AC measurement applications often require electrical isolation to protect the system and user from high voltages. Galvanic isolation is often achieved by using bulky sensor voltage/current transformers or by isolating the data and power interfaces from the measurement subsystem. However, these approaches take up considerable space, have hidden costs and design challenges.
The Sonoma (MAXREFDES14#) power measurement subsystem reference design utilizes a single pulse transformer to achieve electrical isolation from the system and uses a resistor as the sensing element. The result is a small, cost-effective circuit board.
The Sonoma design features an isolated power measurement processor ( MAX78615+LMU) ; a multi-channel, high-precision analog-to-digital converter (ADC) ( MAX78700 ); a pulse transformer; an optional 20MHz crystal; and the ability to convert AC voltage and current into a Detection resistor for measuring signal. Featuring embedded load monitoring unit (LMU) firmware, non-volatile memory for calibration and configuration data, Sonoma is a complete measurement subsystem that can be integrated into any design.
Sonoma subsystem design block diagram
Figure 1. Sonoma subsystem design block diagram.
characteristic
application
  • High-precision power measurement
  • High voltage electrical isolation
  • Preset gain/offset parameters
  • Onboard 4mΩ current sense resistor with good temperature coefficient
  • On-board voltage sensing resistor divider with a voltage division ratio of 2667:1 and good temperature coefficient
  • Universal AC input voltage range 90 to 264V AC
  • AC pluggable terminal (max. 8A)
  • Small size printed circuit board (PCB)
  • Device driver
  • C language source code
  • Xilinx® LX9 and ZedBoard™ Platform Profiles
  • Pmod™ Compatible Specifications
  • lighting control system
  • Commercial and Industrial Automation
  • renewable energy systems
  • Electric vehicle charging system
  • Smart home applications
Competitive Advantage
  • Built-in non-volatile memory for calibration and configuration parameters
  • Complete electrical isolation using a single transformer
  • Small circuit board size
  • Low BOM cost
参考设计图片
Search Datasheet?
Forum More
Update:2025-08-04 17:40:17
