smallembedded
42 W high power factor constant voltage output flyback converter based on ICL8810
REF_ICL8810_LED_42W_PSR
REF_ICL8810_LED_42W_PSR This 42 W reference design uses Infineon's high power factor flyback controller ICL8810. The evaluation board is a constant voltage (CV) secondary side regulation (SSR) system designed for use with a constant current (CC) converter for LED lighting applications.
Compared with SSR, PSR has obvious cost advantages. The design eliminates the need for components such as optocouplers, voltage references, and error amplifiers. Therefore, the REF_ICL8810_LED_42W_PSR is more cost-effective and an ideal solution for LED on/off drivers or LED drivers with dimming levels as low as 5%.
The evaluation board provides excellent accuracy of ±3.5% over the 10% to 100% output power range.
With its benchmark power factor correction and total harmonic distortion performance at full and light load conditions, the ICL8810 supports window driver and platform designs. In addition, the IC combines excellent efficiency with low EMI characteristics without compromising light quality.
Feature description
  • Constant Voltage (CV) Secondary Side Regulation (SSR) Reference Design for LED Lighting Applications
  • ICL8810 integrates burst mode to achieve very low standby power of less than 100 mW
  • Power factor (PF) > 0.9 and THD < 10%, applicable to a wide load range (AC input up to 277 V rms )
  • Maximum AC input voltage: 90 – 305 V rms
  • Critical conduction mode and quasi-resonant mode supporting smart valley jumping
Advantage
  • Ideal topology for LED on/off drivers with a minimum dimming level of 5%
  • cost optimization
  • The EV kit provides excellent accuracy of ±3.5% over the 10% to 100% output power range.
  • Can create smart lighting
Potential applications
- LED lighting
- Smart lighting
- LED drivers and luminaires up to 125 W
- Adapters and chargers, flat screen TVs, all-in-one PCs, monitors up to 125 W
参考设计图片
Search Datasheet?
Forum More
Update:2025-08-06 19:54:37
