aytwartoofyoroo
MAXREFDES1167: 15V/200mA or 12V/100mA, Iso-Buck DC-DC converter using the MAX17681A
MAXREFDES1167: 15V/200mA or 12V/100mA, Iso-Buck DC-DC Converter Using the MAX17681A
input type V IN (minimum)
(V)
V IN (maximum)
(V)
I OUT
(A)
Output channel V OUT
(V)
P OUT
(W)
Topology
DC 17 36 0.2 single output 15 3 ISO-BUCK
The MAXREFDES1167 is a high-efficiency, iso-buck DC-DC power module based on the MAX17681. It accepts an input voltage range from 17V to 32V and adjusts the output voltage through primary-side feedback. The reference design provides two output configurations: In one configuration, the output is set to 15V @ 200mA with a regulation accuracy of ±8%; in the second configuration, a post-regulator (MAX17651) is used to produce a 12V @ 100mA output with a stable output Pressure accuracy is within ±3%. This iso-buck isolated power module is available in the MAX17681 in a 10-pin (3mm x 2mm) TDFN package and the MAX17651 in a 6-pin TSOT package. The pin spacing of the MAXREFDES1167 complies with the Distributed Power Source Open Standards Alliance (DOSA) open standard for DC/DC module power supplies. Two transformer options are provided, one is from Wurth; the other is from Chinese transformer manufacturer HanRun, which is convenient for users to choose. The reference design provides 1500V electrical isolation.
This circuit board is not for sale.
Key Features
  • +15V@200mA or +12V@100mA output
  • 17V to 32V input voltage range
  • EN/UVLO input
  • 200kHz switching frequency
  • 90% peak efficiency
  • Overcurrent protection
  • No optocoupler design
  • Output power up to 3W
  • Thermal Protection
  • Proven PCB layout
  • Primary and secondary output voltage short circuit protection
design resources
Design, build and test
This reference design introduces the MAXREFDES1167 hardware circuit design and provides detailed technical guidance for designing iso-buck converters using Maxim's MAX17681A current-mode controller. The power supply has been built and tested.
参考设计图片
Search Datasheet?
Forum More
Update:2025-07-25 07:51:19
