555 practical DC stepless dimmer circuit diagram
Source: InternetPublisher:他们逼我做卧底 Keywords: Stepless dimming circuit diagram dimmer Updated: 2021/04/15
The circuit is shown in the figure, and the dimmer is composed of 555 as the core. 555 and R1, RP, R2, C1 form an astable multivibrator. The oscillation frequency is f=1.44/(R1+RP+R2)C1, which is about 650Hz. The duty cycle can be changed by adjusting RP, which can be changed from From 4.5% to 95.5%, the brightness of the lamp changes in a wide range, achieving stepless dimming .
- Voltage divider circuit calculation formula, where to find the voltage divider circuit?
- What is a pure resistance circuit? What is a pure resistance AC circuit?
- What does a rectifier do? What is the process of rectification?
- Basic characteristics/working principles and application circuits of tunnel diodes
- Share a Motorola amplifier circuit
- How to build a triangle wave generator using an op amp and discrete components
- Tutorial on building a NOT gate using BJT transistors
- What is the difference between high-side and low-side resistive current sensing
- Using an Op Amp to Drive a Simple and Practical Power Amplifier
- Circuit diagram of an example of differential and integral circuits
- Pressure signal conditioning circuit circuit diagram based on MAX1450
- Introducing the CD4013 washing machine timer circuit diagram
- Inspection circuit diagram for broken rotor bar of three-phase motor
- Measurement circuit diagram of differential pressure sensing bridge
- Input status indication circuit diagram
- Night target display circuit diagram
- Insulation resistance meter circuit diagram
- Laser flashlight circuit diagram
- Monostable circuit diagram
- LS7232 touch stepless dimming light circuit
