ECM microphone preamplifier
Source: InternetPublisher:兰博 Updated: 2020/05/05
Both transistors are low noise types. In the original circuit, I used BC650C which is an ultra low noise device. These transistors are now hard to find but BC109C are a good replacement. The circuit is very device tolerant and will set its quiescent point at roughly half the supply voltage at the emitter of the last transistor.
The electret condenser microphone (ECM) contains a very sensitive microphone element and an internal FET preamp, a power supply in the range 2 to 10 volts DC is therefore necessary. Suitable ECM's may be obtained from Maplin Electronics. The 1k resistor limits the current to the mic. The output impedance is very low and well suited to driving cables over distances up to 50 meters. Screened cable therefore is not necessary.
- What is the function of a voltage regulator in a circuit? How to connect a voltage regulator?
- What is the difference between single-phase and three-phase power? When is three-phase power required?
- The Importance and Ideal Model of Impedance Matching
- Transfer characteristics of BJT, how to apply Shockley equation?
- What is a D flip-flop and how does it work?
- How to Build a Simple Temperature Indicator Circuit Using NTC and PTC Thermistors
- Causes of PCB deformation How to prevent circuit board bending and warping
- Summary of knowledge points of multiplexer
- LED Bicycle Lights
- Experiment and production of NE555 time base integrated circuit
- 555 square wave oscillation circuit
- 555 photo exposure timer circuit diagram
- Introducing the CD4013 washing machine timer circuit diagram
- Simple level conversion circuit diagram
- 555 electronic guide speaker circuit diagram for blind people
- Circuit diagram of disconnection alarm composed of 555
- Analog circuit corrector circuit diagram
- color discrimination circuit
- Color sensor amplification circuit
- Level indication circuit
