High Stability Thermocouple Amplifier
Source: InternetPublisher:aytwartoofyoroo Keywords: amplifier thermocouple BSP operational amplifier Updated: 2020/01/28
OP07 has low drift (maximum voltage drift 30 FLV, maximum temperature drift 0.6vV/aC), low noise (maximum
0.6 pLVp.P), ultra-stability (maximum 0.6yV/qC.month), and wide power supply voltage range (t3~ +18V) high-performance
operational amplifier . The parameters of OP27 are relatively close to OP07.
Their pin function diagram is shown in Figure LO-l, and the application circuit is shown in the figure.
When R3:R4, Ri=R2, OP07 forms a differential instrument amplifier, and the amplifier gain is determined by R3/RI.
Figure 10-2 and Figure 10-3 are two examples of common circuits of operational amplifiers. The circuit structure is the same as that of a general operational amplifier
This circuit can amplify the input signal of the sensor and convert it into a 4~20mA current output. The circuit is mainly
composed of an operational amplifier, a reference voltage source, and an output tube. The input voltage is amplified by the operational amplifier and driven by V. After passing through the sampling resistor R6
, it reaches the load resistor Ri. output in the form of current. The relationship between the output current and the input voltage is
/ou-r=(VIN×Rs/Rz +5Rs/R,)/R6
according to the parameters in the figure
/ourr=(16VlN/JOO) +4.O(mA)
- Does lithium iron phosphate battery need a protection board? The correct way to charge lithium iron phosphate battery
- How does a series arrangement of Zener diodes affect the electrical behavior?
- What are the parts of the fpga design process
- Datasheet/Pinout/Technical Specifications of LMC555
- What is a D flip-flop and how does it work?
- Share an interesting LED decoration project
- TL494 pin functions/configuration/ratings/operating conditions/layout diagram
- How to build a triangle wave generator using an op amp and discrete components
- Introduction of TDA4863J/4863AJ TV field scanning IC
- Simple LED advertising light circuit
- Set timing circuit when power is on
- Bone hyperplasia treatment circuit
- Crop anti-frost circuit
- Rural fish farming control circuit
- AC voltmeter
- collector amplitude modulation circuit
- Amplitude modulation circuit composed of MC1496
- ring amplitude modulation circuit
- Schiller oscillator circuit
- superheterodyne radio circuit
