王达业
MAXREFDES32#: Dual Channel Analog Input/Analog Output with Flyback DC Supply
Advanced manufacturing, custom production and cost pressures continue to drive factories toward higher speed performance and greater flexibility. To meet the requirements of "no compromise" factory environments, the MAXREFDES32# subsystem reference design provides two high-speed, high-precision, 400ksps, 16-bit analog input channels and output channels. All input and output channels support ±10V and ±20mA signals, plus 20% margin, providing flexibility for low- and high-speed systems using voltage or current signals.
The MAXREFDES32# design uses four dual-channel fast-stable high-voltage operational amplifiers (MAX9633); two 16-bit 500ksps ADCs (MAX11166); two low-noise, fast-stable, high-precision, 16-bit DACs (MAX5316); two ultra-high-precision 4.096V voltage reference (MAX6126); seven high-speed digital isolators (MAX14850); peak-current-mode converter with flyback/Boost supplies (MAX17498B); and +18V, -18V, +5V, and -1.25V linear regulators Power supplies (MAX8719, MAX8881). By using high-precision and high-speed components, the subsystem performs well in both process control applications (such as sensor inputs) and control applications (such as servo drives, resolvers and encoders).
MAXREFDES32 subsystem design block diagram
Figure 1. MAXREFDES32 subsystem design block diagram.
characteristic
  • Two independent analog inputs
  • Two independent analog outputs
  • Isolate power and data
  • High-speed 400ksps analog input sampling rate
  • High-precision 16-bit resolution
  • Voltage output settles to within 2 LSB in 17µs
  • Voltage output settles to within 2 LSB in 77µs
  • Device driver
  • C language source code example
  • ZedBoard™ Platform Profile
  • Compatible with FMC
Competitive Advantage
  • high speed
  • High precision
  • low noise
application
  • Industrial control automation
  • Servo drive
参考设计图片
Search Datasheet?
Forum More
Update:2025-07-27 16:24:22
