Single tube TV antenna amplifier circuit
Source: InternetPublisher:aerobotics Keywords: Antenna amplifier Updated: 2024/08/22
The TV signal from the antenna is coupled to the base of the transistor BG through the capacitor C1, amplified, and then taken out by the resonant circuit composed of inductors and capacitors. L1, L2 and the distributed capacitors at the output end of BG form a parallel resonant circuit with a resonant frequency of 48~92MHz, while the series resonant circuit composed of L3 and C4 has a resonant frequency of 165~225MHz. The entire circuit is staggered and tuned within the passband range of 48~225MHz, so it can amplify the TV signal of any channel in the VHF band.
- Semiconductor fuse symbol diagram, semiconductor fuse working principle, how to select semiconductor fuse
- Differential amplifier formula, Wheatstone bridge differential amplifier circuit analysis
- How to judge the design quality of printed circuit boards?
- What is a photocoupler and how to select and use one?
- What does a rectifier do? What is the process of rectification?
- In-depth analysis of energy losses in oscillation frequencies
- How to read resistor color codes? Resistor color codes illustrated
- Working principle/advantages/disadvantages/size of optical fiber
- Share an interesting LED decoration project
- Causes of PCB deformation How to prevent circuit board bending and warping
- 555 square wave oscillation circuit
- 555 photo exposure timer circuit diagram
- Introducing the CD4013 washing machine timer circuit diagram
- Simple level conversion circuit diagram
- 555 electronic guide speaker circuit diagram for blind people
- Circuit diagram of disconnection alarm composed of 555
- Analog circuit corrector circuit diagram
- color discrimination circuit
- Color sensor amplification circuit
- Level indication circuit
